[New] Servos série RSx par Ko Propo
+7
Jojo 38
11 participants
Nombre de messages : 28001
Mer 20 Oct 2010 - 23:29
Servos série RSx
par Ko Propo
Lien Ko Propo
KO Propo have released their new RSx (Racing Servo) series of servos. These new servos are the result of two years of R&D for both on-road and off-road. The new servo line features all new materials for increased strength and new programming to take advantage of today’s current technology.
Internal Improvements:
- The servo gears are cut in house for the best Quality Control from “special Japanese aluminum” for superior hardness and wear. This aluminum is 30% lighter and 20% stronger then steel.
- The servo amplifier and processor has been re-worked and optimized for Lipo direct voltage but will still operate when used with NiMH cells.
- A new core-less motor for the higher voltage is used to further enhance the use of the LiPo technology.
- New ICS programming and new software will be available via PC or the RSx setting card.
External Improvements:
- The middle case is a one-piece machined aluminum part so the gears and gear pins are held properly in place without any plastic insert that will wear out.
- The standard RSx features a new upper case redesigned with increased rigidity on the mounting tabs. The H.C. (Hard Case) versions of the RSx include a machined upper case for maximum rigidity.
RSx Response H.C. 30100 (Digital Servo, Speed Type, Hard Case)
Voltage: 6V or 7.4V
Torque @6V: 200.1 oz-in, 14.5 Kg-cm
Torque @7.4V: 242.9 oz-in, 17.6 Kg-cm
Speed@6V: 0.07 S @ 60°
Speed @ 7.4V: 0.06 S @ 60°
Bearings: Yes, DBL
Lead Connector: Gold plated
Gears: Full metal
Weight: 70.5 g
RSx Power H.C. 30101 (Digital Servo, Torque Type, Hard Case)
Voltage: 6V or 7.4V
Torque @6V: 362.9 oz-in, 26.3 Kg-cm
Torque @7.4V: 436.1 oz-in, 31.6 Kg-cm
Speed@6V: 0.13 S @ 60°
Speed @ 7.4V: 0.11 S @ 60°
Bearings: Yes, DBL
Gears: Full metal
Weight: 70.5 g
RSx Response 30102 (Digital Servo, Speed Type)
Voltage: 6V or 7.4V
Bearings: Yes, DBL
Gears: Full metal
Weight: 65.6 g
RSx Response 30103 (Digital Servo, Torque Type)
Voltage: 6V or 7.4V
Bearings: Yes, DBL
Gears: Full metal
Weight: 65.6 g
par Ko Propo
Lien Ko Propo
Voltage: 6V or 7.4V
Bearings: Yes, DBL
Gears: Full metal
Weight: 70.5 g
Voltage: 6V or 7.4V
Bearings: Yes, DBL
Gears: Full metal
Weight: 70.5 g
Voltage: 6V or 7.4V
Bearings: Yes, DBL
Gears: Full metal
Weight: 65.6 g
Voltage: 6V or 7.4V
Bearings: Yes, DBL
Gears: Full metal
Weight: 65.6 g
Re: [New] Servos série RSx par Ko Propo
Mer 15 Fév 2012 - 1:24
KP."Gonzo !"
G. "Oui ?"
KP."Choisi-moi choisi-moi choissiiiii-moiii pour ton BS !"
G."MMMm, c'est vrai qu'il me faut un servo pour celui-là.... la nuit porte conseil..."
KP."Ok mais bouge ton cul"
G."Reste poli."
KP."Oki, bisous"
G."Oui oui bisous aussi..."
G. "Oui ?"
G."Reste poli."
KP."Oki, bisous"
Nombre de messages : 4566
Mer 15 Fév 2012 - 3:59
powarf !!!
Mer 15 Fév 2012 - 4:07
Nombre de messages : 1059
Mer 15 Fév 2012 - 13:53
Mer 15 Fév 2012 - 15:04
Sacré Gonzo...
Mer 15 Fév 2012 - 16:58
Y'en a pas 2 pareils
Mer 15 Fév 2012 - 20:06
J'espère que Ko Propo ne me décevra pas...vu le prix du 30101.
Mer 15 Fév 2012 - 23:04
J'espère que c'est aussi bon qu'un Hitec (qui eux aussi les donnent pas leur servos)!!!
Mer 15 Fév 2012 - 23:09
Personnellement je n'achète plus de Hitec 1/8, j'en ai cassé/brulé pas mal...trop même et pas des petits...
Et puis vu tous les petits bijoux qu'il y a sur le marché pourquoi taper dans du Hitec.
@Aureli1
Wouep c'est son seul défaut pour l'instant.
Je ne connais pas très bien les Big servos Ko Propo et encore moins la nouvelle série RSx.
Chez KoPropo, j'en ai testé seulement un, un petit, sur un Buggy 1/10 (X11) et RAS.
Il n'y pas de vrai de retour pour l'instant.
Sur RCTech, un forum que j'aime beaucoup lire (très à la pointe), pas mal de personnes en ont acheté mais ils ne donnent pas de retour...Au moins, ils ne donnent pas de "mauvais" retours. C'est un peu comme moi avec mon JR DS8711 qui est magnifique au passage (Je le conseille grandement). Donc ça ne peut-être que bon signe !
@Aureli1
Mer 15 Fév 2012 - 23:12
Alors je vais les retirer de ma Wish List les Hitec !!!!
Merci du conseil
Merci du conseil
Mer 15 Fév 2012 - 23:17
Peut-être que maintenant ils se sont améliorés...mais on va dire que j'ai donné dans Hitec, donc personnellement je ne retenterais pas.
Et attention c'est en 1/8 que j'ai eu beaucoup de problèmes mais en mini et micro > RAS.
Mer 15 Fév 2012 - 23:32
Celui-ci c'est un 1/8 ou 1/10 alors ????
Mer 15 Fév 2012 - 23:48
0.17 sec/60° - 44.0 kg-cm (611 oz-in) @7.4V oui un 1/8 !
Vu le prix, je taperais direct dans un JR HV ou un Sanwa/Airtronics.
Jeu 16 Fév 2012 - 0:00
Mais comment tu fait pour dire que c'est un 1/8, c'est ca ma plus grande interrogation ???
Jeu 16 Fév 2012 - 0:20
Taille & Spec.
Jeu 16 Fév 2012 - 8:23
Petite précision.
Quand je dis servo 1/8, à la base cette taille sert pour les véhicule 1/8 mais bien sûr on peut aussi les mettres sur la plus part des échelles 1/10. (à la direction 8-15kg-cm - logiquement c'est des servos qui sont rapide/60deg).
Jeu 16 Fév 2012 - 12:54
hitec poubelle ... en 1/5 ya pas le choix mais en 1/8 jette moi ca !!!
Nombre de messages : 599
Jeu 16 Fév 2012 - 20:33
Moi j'en ai 2 des servos ko propo, j'ai les PDS-2368-ICS et franchement ca a l'air solide c'est du servo haut de gamme sa se voit . sa commence a faire quelque temp que je roule avec est sa fonctionne toujours bien .
voila a+
voila a+
Jeu 16 Fév 2012 - 22:37
Merci pour ton retour sur ces servos !!!
Ven 17 Fév 2012 - 1:08
Thank !
Jeu 8 Mar 2012 - 11:13
J'ai reçu aujourd'hui mon servo RSx Power H.C. 30101 (Digital Servo, Torque Type, Hard Case)
Je vais l'alimenter en 7.4v donc : 31.6 Kg-cm - 0.11S/60°
Mes premières impressions :
-Déjà le poids du servo : 70.5g (donnée constructeur), on le sent bien en main.
-Le dessus du corps est assez impressionnant; cette masse en alu taillée dans un seul bloc.
-C'est propre, vraiment aucune bavure.
-La partie centrale en alu, est clean. Couleur acier avec dominante un peu verte (vis de la photo de la new)
-Petit joint visible entre le milieu du corps et le bas.
-Bas du corps en plastique, d'ailleurs, vis-à-vis de l'ensemble et du prix...c'est le seul élément qui fait tache dans le décor.
Rien à voir.
-Le packaging est vraiment bien pourri vis-à-vis du produit.
Maintenant reste plus qu'à le tester...en Big Bash...bien sûr.
Place aux photos :
Rien à voir.
Place aux photos :
Jeu 8 Mar 2012 - 12:01
Le boitier est magnifique! Espérons que l'intérieur soit aussi bien fini.
Tu as des palonniers avec?
Jeu 8 Mar 2012 - 12:17
Oui j'espère.
Non pas de palonnier, tu fais bien de le souligner.
