Nombre de messages : 28001
[New] Radio LRP A2-STX Pro 2.4GHz
Mer 24 Mar 2010 - 17:12
Radio A2-STX Pro 2.4GHz
par LRP
With the new A2-STX Pro 2.4GHz transmitter LRP offers a high value for money
transmitter with 2.4GHz technology for all R/C drivers. With its high-end features,
this new transmitter is nothing less than a sensational price/performance package.
The little brother of the successful C3-STX 2.4GHz Pro impresses with its 2.4GHz
system through extremely high reliability and transmission security. Problems with
occupied frequencies are now finally a thing of the past!
Features:
• Crystal- And Interference-Free 2.4GHz Technology: Due to the 2.4GHz technology
you do not need to worry any longer about radio interferences. Problems with busy
frequencies are history!
• End Point Adjustment (EPA)EPA adjusts the maximum angle causing a different turning radius.
It is used to adjust the maximum servo travel for each channel and turning direction in order to
protect your servos against damages due to overturning of the servo above the technical limited
servo travel of your vehicle.
• Fail Safe Function FailSafe sets channel 2 to an upfront defined position in case of a weak or
lost radio signal in order to avoid loosing control of your vehicle. If no pre-setting is done
Failsafe is set to neutral position.
• LRP Quality in a complete package
- New 2.4GHz technology
- 2.4GHz Mini 2-channel receiver
- LED battery status
- Ergonomically grip and steering wheel in pistol grip design
- Outstanding price/performance ratio
- Charge socket for optional rechargeable batteries
- Stylish packaging box
Specifications.
Number of ports 2
Weight 388g
Transmission Frequency 2.4 GHz
Power Supply 8x AA Alkaline Batteries, 12V
Lien LRP
par LRP
Features:
Specifications.
Number of ports 2
Weight 388g
Lien LRP
