[NEW] Pneus Sable/Neige 2.2/3.0" Pro-Line
+2
6 participants
Nombre de messages : 28015
Lun 18 Jan 2010 - 14:33
En 4X4 ou 4X2...A vous de jouer !
par Pro-Line
Sling Shot SC 2.2"/3.0" Tires
Please note: All tires & wheels are sold in pairs, unless otherwise noted.
Slash, Slayer, etc. are registered trademarks of Traxxas L.P.
Turn your Short Course into a sand slinging super truck with Pro-Line Sling Shot SC tires. With 10 monster grabbing _ tall paddles sand and snow are easily overcome.
Features:
* Made from durable XTR compound
* 10 _ tall paddles
* Molded foam insert and supplemental insert included
* 2.2 outer bead and 3.0 inner bead
* Works on glueable wheels and Pro-Line Bead-Loc wheels
* Fits Slash/Blitz Rear, Slash 4x4 Front/Rear
What's included:
* Sling Shot SC Tires Left & Right (2 pcs)
* Molded Foam Inserts (2 pcs)
* Supplemental Inserts (2 pcs)
Search:
1158-00 | Sling Shot SC
Mohawk SC 2.2"/3.0" Tires
If sand and snow is your fix and you've gone with the Sling Shot SC rear tire, then the Mohawk SC is the perfect compliment. A large center rib and smaller outer rib give your Short Course truck immediate steering.
Features:
* Long lasting molded foam Insert
* Dual rib design for explosive steering
* 2.2 outer bead and 3.0 outer bead
What's included:
* Mohawk SC Tires (2 pcs)
Search:
1157-00 | Mohawk SC
par Pro-Line
Features:
* 10 _ tall paddles
What's included:
Search:
Features:
What's included:
Search:
1157-00 | Mohawk SC
Re: [NEW] Pneus Sable/Neige 2.2/3.0" Pro-Line
Lun 18 Jan 2010 - 15:13
A quoi sert les Sling Shot SC 2.2"/3.0" Tires! Ils sont vraiment bizarre!!!!!!
Lun 18 Jan 2010 - 15:51
Pour le sable et la neige comme noté dans le titre.
Nombre de messages : 3170
Lun 18 Jan 2010 - 16:17
Ce sont des pelles pour mieux accrocher sur sable, neige, eau ...
Nombre de messages : 4567
Lun 18 Jan 2010 - 16:27
Flo65 a écrit: eau ...
ca sentirais pas le wather crossing chez toi flo ??
avec un slash 4x4
a la façon formula off road
Nombre de messages : 1124
Lun 18 Jan 2010 - 17:29
Question: en 4x4, on met 4 Slingshot, Ok, mais ces "sand paddle" n'ont pas d'accroche "latérale", donc même en 4x4, es-ce que ça braquerait bien ? Faut-il quand même mettre les Mohawk à l'avant ?
Lun 18 Jan 2010 - 18:17
4 paddles, quand tu tourne les roues vont prendre l'adhérence sur les coté ou sur tourne .....
Lun 18 Jan 2010 - 19:21
Je pense que les roues avant devraient tracter la voiture sur le côté, oui ! Mais j'ai peur que la poussée des roues arrière et le manque d'adhérence en latéral quand on braque ne pousse le chassis tout droit
Lun 18 Jan 2010 - 19:29
regarde les vidéo de CHX
Lun 18 Jan 2010 - 19:35
Après ça dépend ... sur sable, no soucy ! mais neige/glace, ça peut glisser. Je m'achèterai ces pneus !
Lun 18 Jan 2010 - 19:37
sable / neige c'est pareil ...
glace c'est pas fait pour ....
quand tu roule pneus piste sur la terre ca tire droit ????
réfléchie un peut ....
Lun 18 Jan 2010 - 19:43
Lun 18 Jan 2010 - 19:52
padbol a écrit: Mais j'ai peur que la poussée des roues arrière et le manque d'adhérence en latéral quand on braque ne pousse le chassis tout droit
tu oublie ce que tu dit ....
Lun 18 Jan 2010 - 19:59
Ben les deux peuvent se produire ... simultanément ! Quand tu arrive à pleine balle sur un circuit terre avec des crime fighter, tu vas mieux virer qu'en arrivant pleine balle sur du sable et des pneus striés seulement dans 1 sens
Lun 18 Jan 2010 - 20:04
on ralentie toujours avant de tourner .... et on accélère dans le virage ....
tu est pas prêt de passer le permis toi
bon fin du HS
bon fin du HS
Lun 18 Jan 2010 - 20:20
Oui, c'est sûr, vu de ce point on ralentit avant de freiner, obligé
Bref ! Ces pneus me plaisent bien, reste à trouver les jantes qui iront avec
Lun 18 Jan 2010 - 20:28
des jantes de SC
tu a de plus en plus le choix
entre proline, Jconcept, Ofna, asso, losi, traxxas etc
http://www.amainhobbies.com/index.php/cPath/1_26_1253/n/Cars-Trucks-Off-Road-Tires-Wheels-Short-Course-Wheels
Lun 18 Jan 2010 - 20:30
Pas mal Je pense mettre les Traxxas pour l'esthétisme
Mar 19 Jan 2010 - 2:57
Lorsque j'ai acheté mes Pro-Line Sand Paw, j'ai hésité avec ceux-ci.
J'ai choisi les Sand Paw parce que j'ai l'impression que les autres vont se bourrés de neige dans la cavité des lamelles donc réduire leur efficacité ?
Mar 19 Jan 2010 - 18:31
Si tu as toujours la "lamelle" qui dépasse, qu'elle soit pleine ou creuse, ça va... Par contre si y'a de la neige qui s'entasse entre les pelles, ca va faire une roue lisse ... mais ça c'est avec tous les pneus
- Roues/pneus/Pneu Sable/Neige 2.2"
- Pneus Paddle/Sling Shot 1/8 E-Revo/Revo/Summit Sable/Neige
- Pneus sable sur Erevo 2.0
- [NEW] Pneus/Pneus Badlands MX38 3.8" prémonter sur jantes/jante F-11 Black 1/2" Offset par Pro-Line
- [NEW]Powerhobby 1/5 4.3" 1/8 3.8" 1/10 2.8" Rooster Belted Paddle Sand Snow Roue Rooster Sable Neige
