Nombre de messages : 28002
[NEW] Radio MX-3X FHSS-3 Sanwa
Ven 27 Nov 2009 - 2:57
Powerful, Light and Fast
•MX-3X - Fastest Response in the World
•Ultimate Receiver Reliability
•Easy-to-Use
Highlights:
1) The world's fastest response with newly developed microcomputer system in this category.
2) Dedicated 2.4Ghz system in combination with a 6 cell Ni-MH battery results in a much lighter radio
3) Strong tolerance to heat and a low-voltage tolerance to 2.0V results in a receiver that will not brown out or fade due to temperature spikes and voltage drops.
4) Compatible with the full line of Sanwa Car 2.4Ghz FHSS-2/FHSS-3 receivers.
MX-3X transmitter can use Sanwa brand 2.4GHz FHSS-2 receivers ( FHSS receiver of M11, FHSS receiver of MX-3FG and receiver) and M11X FHSS-3 receiver.
Key Features:
•3 Channel Computer Radio With Advanced Programming for Competition Cars, Trucks, and Boats
•Compatible With Current SANWA/AIRTRONICS 2.4GHz FHSS-2/3 Surface Receivers
•Model Names Can be Assigned
•High-Power FHSS-3 Technology Gives The Best Reception And Connectivity Giving Racers Added Assurance
•18 Model Memory
•Exponential Control Settings for Steering and Throttle
•ST, TH Speed
•AUX SW (H⇔L)
•Position AUX(2-6 position)
•Step AUX (Available for step setting)
•CRAWLER MIXING
•2 ESC mixing (TH Hold function)
•Brake mixing (BR Hold function)
•AUX mixing (ST → 3CH, TH → 3CH)
•Failsafe (FH3F/FH3 mode only)
•Battery Failsafe (FH3F/FH3 mode only)
•Editing function for model name/Mode name indication function
•Mode Type(FH3F/FH3/FH2)
•Key Assign (Trim key)
•Key Click (on/off)
•Battery Alarm (on/off)
•Battery type (4cell/6cell)
Lien Airtronics
•Easy-to-Use
Highlights:
Key Features:
•18 Model Memory
•ST, TH Speed
•AUX SW (H⇔L)
•CRAWLER MIXING
•Key Click (on/off)
Lien Airtronics
