Nombre de messages : 28015
[New] MaxAmps Green Series Life 4500 2S2P 6.6V Battery Pack
Ven 12 Juin 2009 - 0:44
4500 2S2P 6.6V
MaxAmps.com brings you the exclusive "Green Series" LiFePo4 battery packs. These new "life" packs will not catch fire or explode from over-charging. In addition to being safer than lipos, they are more robust.
They provide 1000+ usable cycles(4 times longer than lipos) under the same discharge conditions which makes these new packs the ultimate in performance and value. The new 4500mah 6.6V pack can be safely charged extremely fast using our Hyperion line of balance chargers under the LiFePo4/A123 setting.
Features:
Perfect fit in all standard rc car battery trays.
Up to 15C balance charge rate(67 amps) for quick charging.
1000+ usable cycles.
Inherently safe technology.
Low voltage cutoff is not required.
> 4500mah Capacity
> 6.6 Volts
> 45mm X 138mm X 26mm(same flat format as lipos)
> 30C Constant(135 amps)
> 60C Burst - 1780 surge watts(270 amps)
> 320 grams
> Water-sealed for all-weather protection
> Comes standard with Hyperion taps
> Comes standard with 12awg Deans Ultra wire
> We add the connectors and balancing taps for you
> Money Back Guarantee
> Normally ships within 24-48 hours
> Exceeds safety standards of the IATA
> Built today with factory fresh cells
> Can be recharged unlimited times per day
> Copper Tab Cells for lower resistance
> Low-maintenance and user-friendly
> Environmentally friendly
Lien MaxAmps
4500 2S2P 6.6V
Features:
> 4500mah Capacity
> 6.6 Volts
> 320 grams
Lien MaxAmps
