Nombre de messages : 28001
[NEW] Chargeur TP1430C par Thunder Power
Dim 23 Oct 2011 - 18:46
Chargeur TP1430C
par Thunder Power
Features:
_Powerful 1000W charger, discharger and cycler system with built-in LiPo/LiIon/LiFe (A123) cell balancer
_ Includes a balance connector adapter board readily compatible with 2-14S Thunder Power and JST-XH balance connectors
_This powerful and compact single port design charges, discharges and cycles 1-14S LiIon/LiPo/LiFe (A123), 1-40 cell NiCd/NiMH and 6-48V Pb (lead-acid) batteries
_Up to 1000 watts of total power with selectable charge rates from 0.2 amps up to 30 amps for ultra-fast charging
_12 user-programmable memories plus built-in data monitoring and viewing with internal resistance measurement and more
_Fully-adjustable charge capacity limit (NiMh/NiCd/Pb), per cell end voltage and low voltage cutoff settings to maximize safety, charge and discharge performance
_Wide 12.0-36.0V input voltage range with adjustable input power current limiting to maximize performance and protect power supplies
_Durable and compact aluminum case with dual computer-controlled cooling fans and an extremely easy-to-read blue backlit LCD screen
Thunder Power RC
Source Big Squid RC
par Thunder Power
Features:
Thunder Power RC
Source Big Squid RC
Nombre de messages : 1505
Re: [NEW] Chargeur TP1430C par Thunder Power
Dim 23 Oct 2011 - 19:16
c'est une véritable surenchère chez les fabricants de chargeur !!!
après va falloir trouver une alim' qui suive
Summit Brushless
Hop hop hop....
Dim 23 Oct 2011 - 21:41
Les chargeurs Thunder Power sont des Hyperion rebadgés améliorés.
Le TP1430C est un mono TP820CD qui lui est un rebadgage amélioré du Hyperion EOS 0615i DUO3+, c'est ce que j'ai... un p'tit bijou.
Lun 31 Oct 2011 - 10:19
Mise à jour infos & liens.
