Nombre de messages : 27979
[New] Chargeur Hyperion EOS 0720i Super DUO3 2x7S 20A 1000W
Mer 16 Mar 2011 - 8:30
Chargeur EOS 0720i Super DUO3
2 x 1S-7S, 20A max, 1000W
par Hyperion
* Hyperion's most powerful charger to date!
* 1000W total - 500W per port
* Charger delivered with HP and XH lipo adapter plates, USB cable and clips.
* EOS 0720i SDUO3 DC INPUT 11V~28V
* Charge a split-pack in network mode using both ports for up to 14S at 1000W max.
The EOS 0720i Super Duo is Hyperion's flagship charger for 2011 - now available for ordering.
The Super DUO is not to be confused with past models bearing the 0720 designation as they were all single-port chargers.
This charger is sporting two identical output ports, each port capable of providing 500W of raw charging power.
"0720" is to be interpreted as 7 Cells max - 20Amps max - per port, being a DUO charger.
This is a nomenclature consistent through the Hyperion charger range.
In order to provide all 500W per channel (1000W total), the Super DUO needs 24V-28V of input voltage but can naturally
also be operated on lower input voltages (from 11V).
By popular request, Hyperion is for the first time offering two displays in a DUO charger. The benefits are obvious - easy
monitoring and less confusion. Like the past DUO's, operation is from a single set of buttons with a channel selector.
The EOS 0720i Super DUO3 is Hyperion's most powerful charger to date!
Lien Hyperion
Liens intéressants concernant l'alimentation : A / B / C
par Hyperion
Lien Hyperion
Re: [New] Chargeur Hyperion EOS 0720i Super DUO3 2x7S 20A 1000W
Ven 18 Mar 2011 - 20:44
Ven 18 Mar 2011 - 23:49
Pour le Québec peut-être mais pour la France non > Input Voltage: 110-120V
Il faut taper, par exemple, chez EPower 1200W-40A.
Ou dans la gamme alimentation Grauper, même rebadgage que EPower.
Sam 19 Mar 2011 - 14:49
Je viens de vendre mon Robbe.
Je me tâte pour prendre ce modèle ou un Simple Robbe Power Peak I4 EQ-BID.
Le plus du Hyperion, c'est sa puissance et quelques options sympas.
Le plus du Robbe Power Peak I4 EQ-BID c'est son menu est ses options qui sont l'évolution du Robbe Infinity III...
Que faire que faire...
- castekRevoiste Padawaaa qui powaaaAA
Nombre de messages : 227
Dim 20 Mar 2011 - 15:44
Acheter les 2?
Dim 20 Mar 2011 - 15:47
Bah écoute, excellente idée !
- PattiRevoiste qui se lance Padawaaa
Nombre de messages : 14
Mer 14 Mar 2012 - 6:33
Ce chargeur est à priori toujours une référence en modèle Duo et puissant.
Des utilisateurs de celui-ci peuvent-ils nous apporter leur témoignage?
Merci.
Merci.
Mer 14 Mar 2012 - 10:04
Sur le forum, il y a m8mat mais c'est pour une autre utilisation que du RC.
Il ne m'a pas donné de mauvais retours donc apparemment c'est que ça roule.
Sinon les retours sur les forums sont nickels, rien à dire.
La qualité Hyperion est bien connue, ils font du bon matos.
Personnellement j'ai le modèle EOS 0615i Duo3+ (2x 15A / 300W).
Je vois que tu as déjà une idée sur l'alimentation que tu pourrais lui coller.
Mer 14 Mar 2012 - 15:26
Oui tout à fait, à gros chargeur, grosse alim.!
Mer 14 Mar 2012 - 18:50
Coucou !
Exact Chezoit ! Je n'utilise pas exactement celui là mais la version 14s 550w en double exemplaire. Ca marche du tonnerre. Et par contre je vais peut-etre craquer pour la dite alim car j'ai fait cramer l'une des miennes et je ne trouve pas la panne....
Par contre je n'arrive pas à faire reconnaitre mon chargeur par le PC avec le cable fourni, je ne sais pas si ça vient du pc ou non. En tout cas si certains ont réussi à faire marcher le logiciel hyperion je suis preneur !
Bonne soirée
Mat
Bonne soirée
Mat
