[New] Radio TG-04C 2.4GHz 3ch par ERC
+2
6 participants
Nombre de messages : 27979
Dim 20 Nov 2011 - 19:48
par ERC
ERC TG04C 2.4GHz Digital Proportion Radio System With Color Screen
Feature:
1.Be used for Professional RC Car and RC Boat.
2.2.4 inch TFT color Screen Display
3. DPI 1024(256)
4.Display English&Chinese two languages (also,we can do any languages as per your requirement)
5.Can be individually adjusted data for each types of ESC (include RC car and RC boat)
6.Reversible Hand Operation(wheel section can be installed to left-or right hand driving)
7.Real-time dynamic screen
8.Stopwatch function
9.10-model memory,control distance:150M
10.Exponential(EXP Steering and Thorttle)
11.Steering dual rate (d/r-st)
12.Anti-skid braking system (ABS)
13.Digital trim: Steering trim, throttle trim, steering d/r
14.Function select lever function (fnc-dt1/ dt2/dt3/dt4)
15.Tension adjustment funciton.
Technical Data:
TX module: Size:14* 7* 31cm(L*W*H)
1)Frequency Band:2.400-2.4835GHz ISM BAND
2)Modulation:FSK
3)TX Power:less than 20 dBm typical
4)TX Current:150mA typical
5) Modulation signal: 1-3CH, standard PPM pulse width control signal
6)Working Voltage:DC4.8V-6.0V
7)R/C distance:more than 150m(open ground)
8)automatic select and change frequency(frequency hopping) after turning on the TX
RX module: SIZE:4*2*2cm(L*W*H)
2)Working Voltage:DC4.8V-6.0V
3)RX Current:30mA typical
4)RX Sensitivity:-110dBm typical
5)Demodulate Output signal:standard 1-3CH,signal pulse width1.0-2.0ms
6)LED Indicator light for RX Sensitivity and frequency bind
7)receive range:above 150m(open ground)
ERC
par ERC
Feature:
3. DPI 1024(256)
Technical Data:
2)Modulation:FSK
ERC
Nombre de messages : 1983
Re: [New] Radio TG-04C 2.4GHz 3ch par ERC
Dim 20 Nov 2011 - 21:13
blanc ça craint quand même
Dim 20 Nov 2011 - 21:21
moi , je trouve ça classe !!!
Dim 20 Nov 2011 - 21:28
tant que ça reste propre
Dim 20 Nov 2011 - 22:18
elle ressemble vaguement aux futaba!
Dim 20 Nov 2011 - 23:58
- sonicRevoiste qui se lance Padawaaa
Nombre de messages : 7
Lun 21 Nov 2011 - 13:17
elle est belle mais "receive range:above 150m(open ground)" sa veut dire 150 mettre de portée non ??
c'est pues, meme si a 150M je la vois plus
et la tellecomand traxxas a 300 metre de portée non ???
n'hésiter pas a me corriger si je me trompe
(le pire se serait si elle se retourne a 150 metre)
Lun 21 Nov 2011 - 14:22
150m c'est très très largement assez.
Je n'ai pas trouvé l'information officielle concernant la distance que tiennent les radios Traxxas.
@TPrice
Je dirais même qu'ils ont complètement copié la 4pk/4pks.
@TPrice
