Nombre de messages : 27995
[New] Jantes Desperado 3.8" 1/2 et Zero OffSet par Pro-Line
Mer 17 Aoû 2011 - 1:46
1/2 et Zero OffSet
par Pro-Line
Features :
>Aggressive 6-spoke wheel design
>Molded in Bead-loc ring for scale look
>Works with all 3.8" Traxxas Style Bead tires
>Zero offset wheel for your standard Monster Truck
Description :
This is a pair Desperado 3.8" (Traxxas Style Bead) Black Zero Offset 17mm Wheels. Pro-Line’s highly anticipated new 6-spoke wheel will make your truck the toughest looking one on the block. The Desperado wheels are a one-piece glue wheel made out of extremely durable nylon material. The Desperado wheels feature a molded in bead-loc ring for an awesome scale look. This wheel will accept all Pro-Line 3.8" Traxxas Style Bead tires along with all Stock Traxxas 3.8" tires, giving you a ton of rubber options. This 17mm hex wheel, is sure to make your truck stand out from the rest, so get some today!
Lien Pro-Line
Features :
>½” offset wheel for all the Traxxas Summit fans
Description :
This is a pair Desperado 3.8" (Traxxas Style Bead) Black ½” Offset 17mm Wheels. Pro-Line’s highly anticipated new 6-spoke wheel will make your truck the toughest looking one on the block. The Desperado wheels are a one-piece glue wheel made out of extremely durable nylon material. The Desperado wheels feature a molded in bead-loc ring for an awesome scale look. This wheel will accept all Pro-Line 3.8" Traxxas Style Bead tires along with all Stock Traxxas 3.8" tires, giving you a ton of rubber options. This 17mm hex wheel,is sure to make your truck stand out from the rest, so get some today!
Lien Pro-Line
1/2 et Zero OffSet
par Pro-Line
Features :
Description :
Lien Pro-Line
Features :
Description :
Lien Pro-Line
- [New]Jante 3.8" Desperado Chromée Zero & 1/2 Offset Pro-Line
- [NEW] Pneus/Pneus Badlands MX38 3.8" prémonter sur jantes/jante F-11 Black 1/2" Offset par Pro-Line
- [NEW] Jantes Pro-Line Tech 5 - 3.8" (40 Series) 1/8
- [New] Pro-Line Velocity VTR 4.0" Zero & 1/2 offset
- [FUTURE NEW] Pneus Badlands MX43 Pro-Loc & Jantes impulse Pro-Loc pour X-Maxx par Pro-Line
