Nombre de messages : 27995
[New] Alimentation Super Pro 2000 par ProTek R/C
Mer 17 Aoû 2011 - 1:32
(30V/80A/2000W)
par ProTek R/C
Features:
>110-240V Input
>Four primary 80 amp 4.0mm banana plug clamp terminal outputs
>2000 watts
>Independently adjustable variable voltage and variable current controls
>LED display
>Dual internal cooling fan
>Short circuit protection
>Overload protection
>Over-voltage protection
>Over-power protection
>100% full load burn-in test
Specifications:
>Input Voltage: 110-240V
>Output Voltage: Adjustable 12 - 30V DC (+/- 5%)
>Wattage: 2000W
>Current: 66A @ 30V / 80A @ 25V
>Frequency: 50/60Hz
>AC inrush current: Cold start: 60A @ 100%
>Output Connections: (4) High output 80 amp 4mm banana plug clamp terminal outputs
>Size (LxWxH): 285x190x198mm
NOTE:
>Included cable is only compatible with Type B 110V outlets. Power cables vary from region to region and must be purchased separately.
>Ensure that you DO NOT exceed the maximum 80 amp load when using multiple outputs.
>Verify that the output voltage is set correctly and that you do not exceed the recommended maximum voltage BEFORE you plug in your equipment. Failure to do so will result in damage to your equipment.
#PTK-PRO-2000W-SP
(30V/80A/2000W)
par ProTek R/C
Features:
>110-240V Input
>2000 watts
>LED display
>Overload protection
Specifications:
>Wattage: 2000W
>Frequency: 50/60Hz
NOTE:
#PTK-PRO-2000W-SP
- [NEW]Jantes Super Dish 2.2" 1/10 2WD 4WD - Super Dish, Rustler | Stampede 2.2″ Wheels
- [NEW]ProTek RC Tire Punch Tool - Perforateur de pneus #PTK-1998
- Autonomie E-Revo/B-Revo Combo/Contro/Controleur/moteur Brushless 1/8
- [NEW] KillerBody 1977 Nissan Skyline Hardtop 2000 GT-ES Finished Body for 4TEC2.0 Carro Carrosserie
- [NEW]Prises/Connecteur QS8 8mm avec détrompeur et surtout anti-étincelle ProTek RC - QS8 Anti-Spark
