Nombre de messages : 27979
[New] Radio Hitec Aggressor SRX PRO & 3DS
Sam 3 Avr 2010 - 4:35
Radios Aggressor SRX PRO & 3DS
par Hitec
Aggressor SRX PRO 2.4: 3 Channel 2.4GHz DSSS Computer Radio System
Looking for a feature packed radio for your car or boat? Then take a
look at the 2.4GHz SRX Pro. This three-channel pistol grip computer
radio system is a great upgrade from the stock radio systems available
with most RTR packages. Easy to install, the SRX uses our 2.4GHz DSSS
technology for a "rock solid" signal. With ten model memories and four
character model naming, the SRX is the only radio you need for your
whole fleet of cars, trucks, buggies, and boats.
Programmable Features
• Steering Dual Rate
• Adjustable Steering, Brake and Acceleration Rates
• Steering and Throttle Exponential Rates
• Servo Reversing
• End Point Adjustments
• Sub Trims for Quick and Easy Set-up
• Idle Up
• Timer
• Steering & throttle Expo
Features
• Hitec 2.4GHz DSSS
• Brake ATL Switch
• Dual Mode 3rd Channel (shift or linear)
• Brake Lever Travel Limiter
• 7msec.High Response Mode (14ms. Normal)
• Steering Wheel Tension Adjust
• Progressive Spring Steering
• Transmitter Battery Charging Jack
• 10 Model Memories
• Two Speed Menu Scrolling
• 4 Character Model Naming
• 3 Channel DSSS Micro Receiver
Available Models
*Stock #130241 Standard Aggressor SRX Pro System Transmitter, Atom 3 Micro Receiver, (1) HS-5485HB Digital Servo, requires ( 8 ) AA batteries
*Stock #130242 Aggressor SRX Pro Transmitter & Receiver only Transmitter and Atom 3 Micro Receiver, requires ( 8 ) AA batteries
*Stock #130245 Standard Aggressor SRX Pro Value Combo Transmitter and (2) Atom 3 Micro Receivers, requires ( 8 ) AA batteries
Aggressor 3DS 2.4 - 3 Channel Pistol Grip Radio System
The Aggressor 3DS 2.4GHz DSSS radio system is one of the most
affordable 2.4GHz systems on the market. Unlike other low cost
entry level systems we've loaded the 3DS with features such as
Dual Rate Steering, servo reversing throttle and steering End Point
Adjustments and a push button third channel that can be used for shifting.
Features
• Hitec 2.4GHz DSSS System
• Audible Power Indicator
• Servo Reversing (Channels 1 & 2)
• Interchangeable Rubber Grip Pads in Two Sizes
• End Point Adjustments (EPA) for Steering and Throttle
• Optional Assorted Colored Grip Pads and Tuning Covers for Personalizing Your Radio
• Dual Rate Steering (Adjustable on the Fly)
• Foam Steering Wheel for Comfortable Control
• 3rd Channel Push Button for Shifting
• Charging Jack for Optional Rechargeable Batteries
• 3 LED Battery Status Indicators
Available Models
*Stock #126241 Standard Aggressor 3DS System Transmitter, Atom 3 Micro Receiver, (1) HS-325HB Servo,
*Stock #126242 Aggressor 3DS Transmitter & Receiver only Transmitter and Atom 3 Micro Receiver, requires ( 8 ) AA batteries
*Stock #126245 Standard Aggressor 3DS Value Combo Transmitter and (2) Atom 3 Micro Receivers, requires ( 8 ) AA batteries
par Hitec
• Servo Reversing
• Idle Up
• Timer
Features
• Hitec 2.4GHz DSSS
• Brake ATL Switch
• 10 Model Memories
Available Models
Features
Available Models
- Sharky38Revoiste Padawaaa super motivé
Nombre de messages : 141
Re: [New] Radio Hitec Aggressor SRX PRO & 3DS
Lun 6 Mai 2013 - 23:09
Hello Chezoit,
Tu as posté cette radio... l'as tu?
Je m'étais acheté la SRX pour piloter ma moto, je la trouve pas mal!
Mais comme je ne l'ai pas touché depuis 2 ans je suis un peu perdu!
Mar 7 Mai 2013 - 11:29
Je l'ai testé, mais pas eu.
C'était une bonne radio pour l'époque.
ps. Joli déterrage.
ps. Joli déterrage.
Mar 7 Mai 2013 - 14:40
your welcome!
- [NEW] Radio Lynx 4S 4Ch par HiTEC
- [NEW] RadioLink Radio RC8X - 8 Channels with Full Color IPS Touch Screen - Radio tactile 8 voies
- [OLD/NEW] Radio Step Up RZT 2.4GHz 2 Channel Radio System
- [NEW]JConcepts RENEGADES TIRE & AGGRESSOR 17MM HEX MONSTER TRUCK WHEEL 2.6" X 3.8"Jantes Pneus
- [NEW]JConcepts FLING KINGS TIRE & AGGRESSOR RIME 17MM HEX MONSTER TRUCK WHEEL 2.6" X 3.8"Jante Pneu
