Nombre de messages : 27995
[New] Novalink interface de programmation par la Team Novak
Sam 14 Aoû 2010 - 3:48
NOVAK SE RÉVEILLE ENFIN !
Novalink - Interface de programmation
par la Team Novak
pour Kinetic Racing Brushless ESC™, Kinetic 1S Racing Brushless ESC™ et M2 Dig 3S Dual Brush ESC™
...C'est déjà un bon début...
In addition to Novak’s easy-to-use One-Touch on-board programming interface, the Kinetic Racing Brushless ESC, Kinetic 1S Racing Brushless ESC and M2 Dig 3S Dual Brush ESC can be fine tuned via Novak’s fully adjustable PC interface, the NovaLink Programming Interface (#5440). The optional NovaLink provides users with expanded programming adjustability. It comprises a unique module that easily plugs into the speed control and an included USB cord. Using the integrated software disk, drivers can fine tune the ESC’s multiple parameters by inputting the desired values or using the user-friendly graphic controls. Additionally, each personalized set of parameters can be stored onto a PC to recall and use again later. These custom-made parameter sets can, in addition, be shared with other drivers. The NovaLink will also never be outdated due to the easy-to-download software updates available to NovaLink users on Novak’s web site. Furthermore, the NovaLink is compatible with Windows XP and Vista computer-operating platforms.
In addition to driver file sharing, Novak also plans to create a database of parameter settings for any racing condition or application. Simply, visit the Novak Web site and search for your specific condition or track; download the file and save it to your PC. This will give drivers a starting point when preparing for a race and tips on how properly to adjust the speed control's many parameters. Through Novak’s Profile Selection feature, users can save the parameter setting on their ESC.
PROGRAMMABLE PROFILES (KINETIC)
The NovaLink offers expanded adjustability on a few of Kinetic's and Kinetic 1S's parameters. These profiles cannot be adjusted through the speed control's on-board programmability.
* Fine-tune adjustment for Minimum Brake, Drag Brake, Dead Band and Minimum Drive profiles. These profiles can be minutely adjusted among the preset values featured on the ESC.
* Personalization of the Throttle and Brake Curves (refer to screen shot B)
* Fine-tune adjustment for the LiPo/LiFe Cut-Off Voltage value
* Independent Drag Brake toggle
* Graphical view of ESC and motor temperature sampling (refer to screen shot C)
* Retrieval of transmitter endpoint values (refer to screen shot C)
* Fine-tune adjustment for RPM Select, Applied Timing and Boost Delay
* Ability to store and share settings. A secondary profile can be downloaded onto the ESC from the Novak Web site or fellow driver. The driver's main profile can still be adjusted via the speed control's on-board programming.
* Ability to update the ESC's firmware in the field
Lien Team Novak
par la Team Novak
Lien Team Novak
