[NEW] Triangles/Triangle RPM pour E-Revo 1/16
+10
aventure07
montmass01
Namzar
Thad73
savage69
Quadman
Baptiste
Nitrous
14 participants
Nombre de messages : 27995
Mer 9 Déc 2009 - 12:58
ENFIN LE JEU COMPLET !!!!
Triangles pour E-Revo 1/16
par RPM
Hey Everyone,
I have a quick update for you. Due to the unexpected popularity of
RPM a-arms for the Traxxas 1/16th Scale Mini E-Revo, and from a
suggestion from one of our fine retailers out there, we've decided
to try a new color. The 1/16th Scale Mini E-Revo has a number of
stock and aftermarket upgrades in the color Red, so now our a-arms
for this awesome little monster are available in red as well.
The part numbers and UPC codes are as follows:
#80609 - Rear Upper & Lower A-arms Set - Red UPC #672415806098
#80699 - Front Upper & Lower A-arms Set - Red UPC #672415806998
Best Regards,
Atticus Overbay
RPM R/C Products
______________________________________________________________________________
Rear A-arms for the Traxxas 1/16th Scale Mini E-Revo
#80602 – Rear Upper & Lower A-arms – Black UPC #672415806029
#80605 – Rear Upper & Lower A-arms – Blue UPC #672415806050
In early December, we released our front A-arms for the Traxxas 1/16th
Scale Mini E-Revo with the intent on soon releasing a set of rears. They’re here!
RPM Mini E-Revo rear A-arms are everything our customers have come to expect
from RPM replacement parts – durable, performance-oriented, good-looking,
slop free and strong!
Similar to RPM front A-arms, our rear versions eliminate nearly all of the A-arm slop,
which allows camber and toe angle settings to be more solidly fixed in position.
The result: A smoother, more consistent suspension system with a significantly
reduced tendency for the truck to randomly wander while driving.
RPM rear suspension arms match the same design elements as our fronts: Angled
leading and trailing edges. By incorporating a 30-degree bevel in these areas, we
reduce the chance of breaking suspension parts since the A-arms will naturally try
to transition over objects instead of bluntly plowing into them.
RPM rear A-arms for the Traxxas Mini E-Revo are sold in sets of four – both upper
and both lower A-arms. What’s best is these miniature E-Revo A-arms, like all RPM
molded products, are backed by our industry-leading breakage warranty.
If it breaks (under normal operating conditions), send it in and we’ll replace it!
Suggested Retail Price $14.95 / set
Front A-arms for the Traxxas 1/16th Scale Mini E-Revo
#80692 – Front Upper & Lower A-arms – Black UPC #672415806920
#80695 – Front Upper & Lower A-arms – Blue UPC #672415806951
Upon the release of the 1/16th Scale Traxxas Mini E-Revo, we immediately
started receiving requests for durability upgrades. What better place to start
than the front A-arms? With our guaranteed unbreakable material and a
proven A-arm design based off of our larger, 1/10th scale Revo A-arms durability
for these little monsters has arrived!
Another problem we have been able to eliminate was slop in the suspension system.
In some cases, we found as much as 1/32” of slop in the stock A-arms!
That has been remedied with these new RPM versions. Our A-arms eliminate nearly
all of the A-arm slop, which allows camber, caster and toe angle settings to be more
The result: A smoother, more consistent steering and suspension system with a
significantly reduced tendency for the truck to randomly wander while driving.
Unique to RPM suspension arms is our angled leading and trailing edges.
We incorporate a 30-degree bevel in these areas, which reduces the chance of
breaking suspension parts since the A-arm will naturally try to transition over
RPM front A-arms for the Traxxas Mini E-Revo are sold in sets of four – both upper and both lower a-arms.
What’s best is these miniature E-Revo A-arms, like all RPM molded products, are backed by our industry-leading
breakage warranty. If it breaks (under normal operating conditions), send it in and we’ll replace it!
par RPM
Hey Everyone,
Best Regards,
Atticus Overbay
RPM R/C Products
Nombre de messages : 4565
Re: [NEW] Triangles/Triangle RPM pour E-Revo 1/16
Mer 9 Déc 2009 - 18:54
enfin !!!! ya surement d'autres truc qui vont sortir dans les prochains jours alors
Mer 9 Déc 2009 - 19:00
Courant février ils sortiront les triangles arrière.
Mer 9 Déc 2009 - 19:01
un true track pour le mini, ça serais le pied lol!
Mer 9 Déc 2009 - 19:19
Mmmm Je ne suis pas fan du système True Track > Pas assez réglable.
Nombre de messages : 1172
Mer 9 Déc 2009 - 20:41
Ouais!!!! Ils sont dispo?
Mer 9 Déc 2009 - 20:47
Baptiste a écrit:Ouais!!!! Ils sont dispo?
tu lie des fois ??
Nombre de messages : 1561
Mer 9 Déc 2009 - 22:50
Question peut-être bête mais qu'est ce que vous appelez le système true track ???
Super les triangles RPM ,je les veux!!! dommage pas en rouge!!!
Mer 9 Déc 2009 - 23:10
le true track est un kit triangle RPM qui a pour effet de supprimer les biellettes de parallélisme AR. le réglage reste donc figé.
Mer 9 Déc 2009 - 23:34
tu le règle d'ou parralélisme alors ?
RC18T=Système true track???
Mer 9 Déc 2009 - 23:42
Mer 9 Déc 2009 - 23:50
OK,merci beaucoup Gilou de ton "éclairage" j'avais déjà vu ce système mais j'ignorais que ça portait ce nom,on en apprend tout les jours dans le modélisme!!! (même après pas mal de temps dedans)
--C'est une spécificité RPM pour TRAXXAS ou d'autres marques ont aussi ce système???
Jeu 10 Déc 2009 - 0:15
Nop RPM
Jeu 10 Déc 2009 - 0:17
DSL,je me suis mal exprimé: RPM en fait pour plusieurs marques ???
Jeu 10 Déc 2009 - 0:31
pieces uniquement produite pour le maxx et le revo
Jeu 10 Déc 2009 - 1:09
ce serais cool qu'ils les fassent aussi pour le mini-revo!!!
-super pour ajuster la garde-au-sol(+ facile que de jouer avec les pas inversé des biellettes!
Jeu 10 Déc 2009 - 8:17
quadman76 a écrit:tu le règle d'ou parralélisme alors ?
bah justement, y'a plus de réglage. le kit RPM est fabriqué avec une certaine valeur de para.
Jeu 10 Déc 2009 - 10:06
OkOK
j'ai bien cerné le truc , grâce à la photo de Gilou et vos explications:j'y vois + clair sur ce système!!!
mais je suis un peu du même avis que Chezoit : moins de possibilités de réglages !
merci à toi aussi Nitrous pour ton aide!
Jeu 10 Déc 2009 - 10:10
ouai moin de possibilité, mais pour le bashing, tu t'en **** royale et c'est plus fiable!
Jeu 10 Déc 2009 - 11:57
Doucement Nitrous, il y a des mineurs.
Personnellement, je préfère mon réglage, après chacun son trip.
Mer 6 Jan 2010 - 12:20
Jeu 7 Jan 2010 - 19:26
Voilà enfin le jeu complet !
Mar 12 Jan 2010 - 15:05
c'est vraiment de la bombe ces triangles RPM
-j'ai fait un petit comparatif avec ceux d'origine et y'a pas photo:
- l'épaisseur et la conception des triangles est super-balaise et bien faite!!!
Installation dès ce soir!
(avec les autre pièces-j'ai bien fait d'en prendre aussi des bleus pour la seconde!)
Mar 12 Jan 2010 - 16:23
DU RPM quoi.
Les arrières devrait être très prochainement disponible.
- [NEW] Triangles/Triangle pour Slash 1/16 par RPM RC
- [NEW/OLD] Triangles/Triangle pour Summit 1/8 par Yeah Racing
- [NEW] Triangle/Triangles Inférieur & Supérieur pour X-Maxx par RPM Racing/Upper & Lower A-arms 82352
- [NEW] Triangle Alu NewEra/New Era Racing pour E-Revo 1/16
- [NEW] Triangles/Tirangle avant pour Summit & E-Revo par RPM Racing
