Nombre de messages : 27995
[NEW] Radio CR4T par Absima
Dim 20 Jan 2013 - 12:56
Premier rebadgage de la FS-iT4/FSiT4
Radio CR4T
par Absima
The brand new "C"olt "R"adio "4"channel "T"eam is a brand new "Smart" radio with a large "Brilliant Touch Screen" display. The navigation works through "Icons" which everybody knows from smartphones and tablet PCs.
The big (47 x 79 mm) Touch Brilliant display shows all functions and adjustments. It also keeps you informed about the radio's voltage. The navigation works through icons which everybody knows from smartphones and tablet PCs.
We putted the steering wheel in an outstanding position to keep handling as comfortable as possible. Additionaly the trimmlevers position allows to set trimm, without leaving the model unattended. The steering wheel is changeable from right- to left-handed.
Functions:
A.F.H.D.S. and A.F.H.D.S2. 2,4 Ghz system
4 channel radio
Racetimer
ABS
Servo reverse
Boat modus
Dual rate
EXP
USB function
Set menu in german, english and french
20 model memory
Failsafe
CR4T set includes:
2020003: 2,4 Ghz 4-channel receiver R4FS
2020005: Voltage telemetry module
2020007: Optical speed telemetry module
2020008: Temperature telemetry module
4x AA NiMH Mignon batteries 1000 mAh 1,2V
Lien Absima
Radio CR4T
par Absima
Functions:
4 channel radio
Racetimer
ABS
Servo reverse
Boat modus
Dual rate
EXP
USB function
20 model memory
Failsafe
CR4T set includes:
Lien Absima
- Nombre de messages : 1093
Re: [NEW] Radio CR4T par Absima
Mer 30 Jan 2013 - 3:41
Pas encore dispo je crois.
J'aime mieux les petites roulettes d'ajustement pour le CH3 et 4 sur cette version (vs la FlySky).
Par contre elle fonctionne avec des AA
Je me demande si le Firmware est identique a FlySky ou si ils l'ont amélioré?...
- [OLD/NEW] Radio Step Up RZT 2.4GHz 2 Channel Radio System
- [New] Radio CR3P 2.4ghz 3CH par Absima
- [NEW] WFLY Radio X9 - 9 Ch with touch screen - Radio 9 Voies avec Écran tactile
- [NEW] RadioLink Radio RC8X - 8 Channels with Full Color IPS Touch Screen - Radio tactile 8 voies
- [NEW] Servos Combat Series par Absima / Team C
