[Old NEW] Servo TG Savöx Savox
+6
Revoman
Tracer
10 participants
Nombre de messages : 27979
Dim 15 Mar 2009 - 14:31
Les servos Savöx...TG commencent à se faire remarquer,
donc il était tout à fait normal d'en parler !
TEST DU SC-1258 TG Par FLO65
TEST du SC-1257 TG
SC-1256 TG
0.15 sec/60°
20.0 kg-cm
SC-1257 TG
0.07 sec/60°
10.0 kg-cm
SC-1258 TG
0.08 sec/60°
12.0 kg-cm
Texte Neo Buggy
Savöx is a brand we haven't featured on Neo Buggy before (heard of ?!) but they have some new supposedly great servos with titanium gears and more goodies.
The Savöx SC-125xTG servos series are extremely powerful, fast and equipped with precise cut gears of a titanium alloy. The SC-1256TG model is extremely powerful with 20kg-cm Torque at 0.15 sec/60 ° @ 6.0Volt and the SC-1257TG is extremely quick with 0.07 sec/60 ° with 10kg cm torque @ 6.0Volt. The Savöx servo’s are equipped with a newly developed 12 bits microprocessor which processes the signal impulses even faster and more accurate.
The nice gold/yellow anodized aluminum housing design not only exudes an exquisite style but helps the operating to stay cool and smooth. The servo’s from the Savöx SC-125x series are extremely light, they weigh about 20% less than the other servo’s in the field.
All servo’s from the SC-125x series are equipped with a precision coreless motor which has brought the output performance to the top level smoother, faster and more efficient. Super strong and precise-made Titanium metal gear form as the solid framework of the Savöx servos. The design will make “crumbled gears” history. Totally Green from material to production, Savöx servos are environmentally friendly.
The Savöx SC-125x servo’s are ideal for the serious 1:10 Touring Car, Buggy 1:8, Truggy, Monster Truck and Crawler owner who knows how to appreciate the added speed, strength and durability of a sublime servo.
TEST du SC-1257 TG
SC-1256 TG
0.15 sec/60°
20.0 kg-cm
SC-1257 TG
0.07 sec/60°
10.0 kg-cm
SC-1258 TG
0.08 sec/60°
12.0 kg-cm
Texte Neo Buggy
- TracerRevoiste Jediwaaa WrightMan
Nombre de messages : 1017
Re: [Old NEW] Servo TG Savöx Savox
Dim 15 Mar 2009 - 16:20
Il faut voir le prix mais ca sent le bon matos.
Dim 15 Mar 2009 - 16:35
Je les avais remarqués depuis leur sortie...mais nouvelle marque,
donc je ne voulais pas faire prendre de risques à quiconque sur le fofo.
Mais là, les retours commencent à arriver et ils sont vraiment pas mal.
Question prix, ils ne sont super corrects vis-à-vis des specs + sans oublié le petite plus > "TG" (Titanium Gear)
Dim 15 Mar 2009 - 18:02
Le Sc 1258 me conviendrait bien !
Le boîtier ressemble aux JR non ?
Dommage qu'il soient jaune par contre...
Lun 16 Mar 2009 - 11:35
Juste le bas du boitier qui a une couleur comme le JR, mais sinon le haut est complément différent.
Nombre de messages : 3168
Lun 16 Mar 2009 - 12:47
je connais pas cette marque ...
Mais je crois que je vais prendre le SC-1258 TG pour mon Losi
Je vous tiens au courant des réception !
Lun 16 Mar 2009 - 13:40
Justement je voulais aussi le prendre pour la direction de mon X11.
Je vais attendre tes retours !
Jeu 19 Mar 2009 - 11:46
SAVOX-SC1258 commandé !
j'attends et je test sur le Losi
Jeu 19 Mar 2009 - 19:01
commandé chez qui? A combien FDPI ?
Jeu 19 Mar 2009 - 20:04
Jeu 19 Mar 2009 - 20:55
61€...
Mon Hitec 12 Kg je l'ai payé 50 euros en France je trouve que c'est un peu cher
Jeu 19 Mar 2009 - 21:18
12 kg pour combien en sec?
et puis c'est Hitec ....
Moi je suis anti-Hitec donc au moins comme ça !
Mon ace fait 14.5Kg pour 0.08sec pour 75€
Ven 20 Mar 2009 - 10:19
J'en ai eu pendant longtemps des Hitec, mais dead les deux. Ils ont tenu 2 ans / 2 ans et demi.
Mais bon je leur en est fait voir de toutes les couleurs...
Le plus important pour un servo :
-Qu'il soit soit bien visé à son support.
-Régler toujours la fin de course.
-Début de run : Toujours vérifier si la vis du palonnier est bien serrée.
(Si besoin, je dis bien "si besoin" : une micro goute de frein filé)
-Sur Revo, toujours roulé obligatoirement avec la protection.
Ven 20 Mar 2009 - 19:56
Flo65 a écrit:12 kg pour combien en sec?
0,10s un truc comme ça, pignons carbone 2,4 kg
Nombre de messages : 984
Sam 21 Mar 2009 - 0:18
On a le meme ace flo ? le mien fait 0.10 sec
Sam 21 Mar 2009 - 7:15
moi il fait 0.108sec donc on a les mêmes !
Sam 21 Mar 2009 - 15:28
Il faut faire attention car certains constructeurs donne la vitesse pour 40° ...
Dim 22 Mar 2009 - 15:44
20°
Dim 22 Mar 2009 - 17:14
Oui chez Traxxas les servos c'est 0.08 s pour 20° ^^
[TEST] Servo SAVOX SC-1258TG
Lun 6 Avr 2009 - 7:36
Je viens de recevoir mon Servo SAVOX SC-1258TG.
Caractéristique:
SC-1258 TG
0.08 sec/60°
12.0 kg-cm
Conditionné dans une petite boite en plastique, comprenant:
- servo
- 4 palonniers
- kit visserie
Bonne finition, palonnier solide, simple a monter (comme tous les servos)
Montage ok, donc je test !
Premier et dernier point négatif: bruyant ! quand il est au neutre il "grésille" et donc fait du bruit !
Test a l'arret, rapide, largement assez coupleux pour mon Truggy.
Test en roulage, ben toujours aussi bon, rapidité au rendez vous, réponds tres bien et toujours autant de couple !
Conclusion:
Pour le peu que j'ai roulé avec, il est tres bon ! pas trop cher, je dirais mieux que les Ace niveau rapport qualité/prix. a vous de tester !
Voila, je vous ferrais un rapport des qu'il sera cassé !!!
Photos:
machine de test : Truggy 8ight-t en thermique
Caractéristique:
SC-1258 TG
0.08 sec/60°
12.0 kg-cm
- servo
- 4 palonniers
- kit visserie
Conclusion:
Photos:
Lun 6 Avr 2009 - 15:18
J'ai fusionnée, histoire que l'info ne se balade pas
Lun 6 Avr 2009 - 19:18
Le bruit est vraiment plus important que les autres servos digitaux ?
Lun 6 Avr 2009 - 19:21
enfin le bruit .... on dirait qu'il arrive pas a se mettre au neutre donc il fait du bruit meme a l'arret ... le bruit est comparable a celui des Tower Pro ...
Lun 6 Avr 2009 - 19:35
Ah, tu as pas de problèmes de tringlerie ?
Avec les roues en l'air il cherche aussi le neutre ?
Lun 6 Avr 2009 - 19:38
oui pareil ...
