-39%
Le deal à ne pas rater :
Huawei P30 Smartphone
395 € 649 €
[NEW] Commande de Servo S.Bus Decoder CSBD-1 par Corona Empty [NEW] Commande de Servo S.Bus Decoder CSBD-1 par Corona
le Jeu 28 Nov 2013 - 11:57
Commande 3 Servos S.Bus Decoder CSBD-1
& Carte de programmation
par Corona
[NEW] Commande de Servo S.Bus Decoder CSBD-1 par Corona 0ixo
The Corona S.Bus decoder is a converter which allows you to use conventional (non S.Bus) servo's with an S.Bus system. Converts up to 3 servo's and must be used in conjunction with the Corona CSBP-1 programming card (see related products).
Specs:
Dimensions: 41 x 12 x 9mm
Weight: 15g
Arrow Lien HK
[NEW] Commande de Servo S.Bus Decoder CSBD-1 par Corona Buce.th
This handy size programming card makes programming Corona S.Bus servo's a breeze, simple and easy to use and with many features such as reversing, selecting channel number (1~18), travel adjust, neutral offset and much much more.
Features:
• 3 programming modes (A,B and C)
• S.Bus servo function (A)
• S.Bus decoder function (B)
• Lipo battery voltage indicator for up to 8 cells (C)
• Hand held
• Easy to use sprung loaded programming switches
• Clear easy to read LCD display
• Input voltage for card 4.8~6v
Arrow Lien HK
[NEW] Commande de Servo S.Bus Decoder CSBD-1 par Corona Userba10
